Just learning this software. I started with an SVG in inkscape. Then I saved to a dxf and opened it in bobcadv 30. I added tabs to hold the insides of the letters. When I imported it to sheetcam there were a bunch of breaks. So I went back and highlighted each break and clicked make lines tangenial that worked on about half of them, the other half didn't move. The others that are still left I have tried trimming, extending, etc. Can anyone point me in the right direction of what I am doing wrong. Seems like there should be something that makes them just snap together.
I also attached the svg logo.
Can't get lines to snap together
- Attachments
- KBS_Logo.svg
- (12.55 KiB) Downloaded 69 times
- drawing kbs.dxf
- (220.47 KiB) Downloaded 66 times
Re: Can't get lines to snap together
Ok Here is what I did, the SVG did look ok in SheetCam but none of the letters had bridges (tabs as you called them). I could not use the DXF file not a problem. When I did open the SVG in Inkscape ( I always remove the fill to make it easier to see thing. For some reason the K did not have nodes but it did show as having a path??? So you know to put the bridges in Inkscape letter they must be separate from other letters but the inside and outside must be combines. You then draw a thin box and make it a path, move the box over the letter and click on the letter (using the node tool icon) you will see the nodes forming the letter. Now hold down the shift key and click on the bridge, go to path and click on differents to remove the bridge from the letter.
Thanks so much for the quick response! I appreciate the help.
acourtjester wrote: ↑Tue Dec 15, 2020 5:11 pm Ok Here is what I did, the SVG did look ok in SheetCam but none of the letters had bridges (tabs as you called them). I could not use the DXF file not a problem. When I did open the SVG in Inkscape ( I always remove the fill to make it easier to see thing. For some reason the K did not have nodes but it did show as having a path??? So you know to put the bridges in Inkscape letter they must be separate from other letters but the inside and outside must be combines. You then draw a thin box and make it a path, move the box over the letter and click on the letter (using the node tool icon) you will see the nodes forming the letter. Now hold down the shift key and click on the bridge, go to path and click on differents to remove the bridge from the letter.
K sign.svg
